I have noticed that when you create a family and then use the export to 'Family Types' command to produce a 'txt' file, nested family parameters are not included in the resultant file. The 'txt' file would then not work, or would it?
Can anyone shed some light on this. I have produced a ' Generic Model'family which is dependant on nested 'Generic Families' and have three parameters relating to the nested families. Whilst I have written my own family types 'txt' files I would have no idea to write the parameter value unless you can just duplicate what you would normally include as the value in the 'Family Types' dialog.
Would appreciate some feedback on this please.
Solved by Alfredo_Medina. Go to Solution.
Are you referring to the Family Types parameters not being exported? Please refer to the solution in this other thread: http://forums.autodesk.com/t5/Revit-Architecture/Referencing-nested-family-types-in-a-catalogue/m-p/...
Thanks Alfredo, I followed the link and see that I was on the right lines at least. Gave you a kudo there!
One other thing in relation to this. I have a parameter called "Quoin Style Max<Generic Models>" the '<Generic Models>' being added by Revit. Do I repeat this parameter title in its entirety when editing the 'Catalog File' or can I omit the added post script?
The part that says "<Generic Models>" is actually not part of the name of the parameter. It's just information about the type of families that the Family Type parameter is looking for.
Trying t export family types from a project im working on.. any reason / know how to fix this when it is grayed out?
