Export to Cad has the wrong date
1 REPLY 1
mhamson
243 Views, 1 Reply
Here is a weird one.
Currently when I "export to Cad format" "dwg" the resulting file is created with the wrong date and time.
I am exporting a view of a floor plan with the naming convension "Automatic - Short" and the "Export views on sheets and links as external references" turned off. When i proceed the resulting file has a date of June 25th 2013 at 4:46pm...today is October 16th , 2013 at 9:08am...according to my computer.
I've tried multiple times over the last couple weeks and have had the same result.
The weird part is if I switch to the "Automatic - Long (Specify prefix)" or "Manual (Specify name)"  naming convension the date ends up being correct.
Why would this make a difference? Is there a way to fix this?
The fact that the naming convension doing this and not any of the other settings makes me think it is a Revit issue and not my computer.
Any thoughts?
Has this happened to anyone else?
Mike
1 REPLY 1
MichaelBussiere2
in reply to: mhamson
Thank you for your post.  In this case the file name/date/time is governed by Windows code.  Does this happen for all users who log into your PC and test this?  If you are the only user, please test creating a new windows user to log in and see how the results may compare.  This may help identify the underling culprit if one presents itself within this test.
Michael Bussiere II
Support Specialist
Product Support
