Revit Architecture
New Member
wonderwho17
Message 1 of 3 (224 Views)
Export to CAD - wall assembly components
224 Views, 2 Replies
09-11-2013 04:45 PM
I want to export from Revit 2013 to AutoCAD so that each component of a wall assembly exports to a separate AutoCAD layer. For example on a simple stud wall with drywall on both sides I would like the interior lines on different layers than the lines for the outside faces. Is this possible?
Thanks in advance!
wwho17
CADastrophe
Message 2 of 3 (184 Views)
Re: Export to CAD - wall assembly components
09-12-2013 11:13 AM in reply to: wonderwho17
Hi! Welcome to the Discussion Groups!
In the DWG Export dialog, click on the "Modify Export Setup" button (Browse.JPG) and scroll down to "Walls" in the Layers tab and expand it. Set the Layer for "Common Edges" and "Cut Pattern" for both the Projection Lines and Cut Lines columns to the desired AutoCAD Layer name.
New Member
wonderwho17
Message 3 of 3 (169 Views)
09-12-2013 01:39 PM in reply to: CADastrophe
Thanks for your prompt response! Silly mistake on my part failing to notice the expand option (+) sign beside "Walls". Pays to sleep on it before sending a message at end of day. Thanks again!
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
