@Dzianis.Hk wrote:
Hi everyone! During synchronization with the Central Model I received the following error message: 'As a result of Reloading Latest, there are no types of Stacked Wall left. Create a new type by duplicating an existing Stacked Wall type in the Project Browser.' I made several new types of stacked walls in the project - it didn't help. What could be the solution? Thanks!
The problem may be with the central file... the reason that I say this is due to the first part of the message: "as a result of reloading latest..."
Are other team members having any issues saving to Central? If so then the central file may have... problems...
Are you using copy/monitor by any chance? (just one more thought to help guide you in finding a root to the problem)
You may be looking in the wrong place for the resolution as the rest of the message may be misleading you.
The truth is, I can't imagine why such an error message would even have been created within the program as it isn't possible to "run out" of stacked wall types to syncronize (as in "there are no types of stacked wall left") and can't imagine how creating a new one would help at all.
well, that one was a shot in the dark anyway... without sitting before the problem it's hard to diagnose. Like describing someone with freckles to someone else without using the word freckles... the diagnosis could be anything from chicken pox to skin cancer...
So we have one user that can save to central and others that can't. Are there multiple error messages or just one for each individual? Are the error messages the same on all of those that can't?
Are all users on the same service pack version?
Here is another experiment or two:
Does save to Central and exit (avoiding downloading latest) allow information to be updated in the central model? If not then the reloading isn't the issue, the ability to save to central is.
The user that can save to Central should log on to a different computer and try to make a quick change or two, then save to central... if he/she can then it is a workset/user issue somewhere.
On the computer where the user can save to central, have that user log out, log on as a different user, make a new local copy, and try again. if sucessful this will isolate the computer over the user and possibly point to a SP or some other such issue
If you haven't already tried, then create a new local copy on one of the affected computers and try again with that copy... repeat the process with the user that can save to central. Can he/she still do so with the new copy? (depending on the results you could have corrupted local files or a corrupted Central)
and with that, I think I'm out of ideas as to how to help figure this thing out for you. I'd have to be sitting there with you to get any further.
Thanks for your responses, Gary!
I tried to make a new Local for user, that couldn't synch - now he can. But now user, that could synch before - can't synch. Hereby only one user can work with Central correctly.
I attach the purged template on which Central was based. I will be very grateful if you try to make Central and some Local files and try to synch them and maybe can understand what the problem is (most likely with this template).
at first glance (and it wasn't me to provide the potential solution but Revit itself)... you have an add-in on your system that I do not haveand I therefore got a warning pointing me in that direction (see attached image of 3rd party warning) ...
That add-in has embedded information into your template that may be messing with your worksharing. I get to that conclusion quickly since you say that starting with a default template doesn't cause your issue...
If this truly is the case you will need to contact whomever wrote that add-in to see how to resolve the issue since only they have the code and know what is being dumped into your file..
On a side note: what language is that? (yeah, I know, Curiosity killed the cat)
