I am creating a tunnel with a profile consisting of multiple radios. In the attached images can be displayed. The problem I have is that by selecting one of the two tunnels and create a void with the profile of the second tunnel and perform cutting geometry indicates that I can not and I get the error message.
If I perform the same exercise to select a tunnel and create a void with a square profile, rectangular or cylindrical deaja if I make the cut geometry. I select the void that did work and edit it to add the profile you require and at the end of the model throws me the error again.
We are working on four computers of the same features and the same version of Revit Building Design Suite 2013, has installed the update 2.
Greetings,
Mr. Alexis
