Revit Architecture
Valued Contributor
tstewart
Message 1 of 3 (316 Views)
Error Messages
316 Views, 2 Replies
06-16-2010 01:40 PM
Newly installed renewal of Revit Architecture 2011 and I keep getting error messages "One time process update " and "There are identical instances in the same place. This will result in double counting in schedules."  whenerver I open a project. How can I remove these notices?
*Expert Elite*
Alfredo_Medina
Message 2 of 3 (301 Views)
Re: Error Messages
06-16-2010 08:20 PM in reply to: tstewart
The "One time process update" message displays when you open a project that was saved in a previous Revit version. That is normal, and the message will display only the first time you open and old project. Now, if the message displays every time you open a new project, then it's your template. Check in Big R (application menu) General tab > File locations > Default template file > whether the path contains  "...\RAC 2011\...Templates\,...
The other error message, "There are identical instances in the same place. This will result in double counting in schedules", means tnat you have inadvertently created a duplicate of an object at the same place. A floor, or a wall, etc. Sometimes, when copying and pasting from one floor to another, the user issues the command twice, causing the error to display.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Contributor
tstewart
Message 3 of 3 (293 Views)
Re: Error Messages
06-17-2010 01:45 AM in reply to: Alfredo_Medina
Thank you :robothappy:
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
