Revit Architecture
*Doug
Message 1 of 8 (69 Views)
Error: Create File Cannot access Revit or ADT2005
69 Views, 7 Replies
05-05-2004 08:46 AM
Attached are the error messages I get when I attempt to open Revit 6.1 or ADT 2005 HELP!!!! Has anyone seen these before? I did my usual HD clean up... I do it once a week. I used both of these programs in the morning and when I re booted after lunch this happened!!! Hope someone has a solution ... Got projects to get out the door!!!! Thanks Doug Attachment not added (too many attachments): "Error 2.JPG"
Distinguished Contributor
JeffreyMcGrew
Message 2 of 8 (69 Views)
Re: Error: Create File Cannot access Revit or ADT2005
05-05-2004 09:31 AM in reply to: *Doug
When you say 'cleanup' what do you mean? What cleanup tool are you using?
Also I've never seen this pop up with Revit. Is it the exact same message between ADT and Revit? That's way strange if that's the case, for the two couldn't be more different in terms of libraries and such...
Jeffrey McGrew
AEC Technologies
*Doug
Message 3 of 8 (69 Views)
05-05-2004 09:41 AM in reply to: *Doug
Disk Clean up and Defrag that comes with windows, I also use Spybot.. but I restored all of the cookies that it removed. Also I tried a system restore to a previous date... no help "JeffreyMcGrew" wrote in message news:7331246.1083774738757.JavaMail.jive@jiveforum1.autodesk.com... > When you say 'cleanup' what do you mean? What cleanup tool are you using? > > Also I've never seen this pop up with Revit. Is it the exact same message between ADT and Revit? That's way strange if that's the case, for the two couldn't be more different in terms of libraries and such... > > Jeffrey McGrew > AEC Technologies
*Jeffrey McGrew
Message 4 of 8 (69 Views)
05-05-2004 09:45 AM in reply to: *Doug
Doug wrote: > Disk Clean up and Defrag that comes with windows, I also use Spybot.. but I > restored all of the cookies that it removed. Also I tried a system restore > to a previous date... no help I doubt that something like Spybot messing with your Cookies would create this error. And Defrag probably wouldn't cause this either, unless something went totally wrong. System Restore might not catch the problem if it's not related to your Registry or Windows. And it's the same error no matter whether you try to run Revit or ADT? Jeffrey
*Doug
Message 5 of 8 (69 Views)
05-05-2004 09:58 AM in reply to: *Doug
Same error... I have uninstalled both programs and re installed them in every combination possible. same error message. I ran Norton's clean sweep and re installed them ... same error message Any ideas? Doug "Jeffrey McGrew" wrote in message news:40991a27$1_2@newsprd01... > Doug wrote: > > > Disk Clean up and Defrag that comes with windows, I also use Spybot.. but I > > restored all of the cookies that it removed. Also I tried a system restore > > to a previous date... no help > > I doubt that something like Spybot messing with your Cookies would > create this error. And Defrag probably wouldn't cause this either, > unless something went totally wrong. > > System Restore might not catch the problem if it's not related to your > Registry or Windows. > > And it's the same error no matter whether you try to run Revit or ADT? > > Jeffrey
*Kenny
Message 6 of 8 (69 Views)
05-05-2004 02:14 PM in reply to: *Doug
Have you verified that this temp folder exists? If so, is it perhaps set to read only? Kenny McNeil
*Doug
Message 7 of 8 (69 Views)
05-05-2004 04:23 PM in reply to: *Doug
Temp folder exists and I can save files to it. This does not explain why I cannot uninstall Revit and reload it. I tried to repair the file with the uninstaller... no luck... I think I have tried every combo on install. Any other Ideas? Doug "Kenny" wrote in message news:409957c4_2@newsprd01... > Have you verified that this temp folder exists? If so, is it perhaps set to > read only? > > Kenny McNeil > >
*v.valentijn
Message 8 of 8 (69 Views)
05-06-2004 12:49 AM in reply to: *Doug
Doug, AdskScSrv.exe is the Autodesk License Service for Autodesk standalone license activation. The file in the temporary folder [AdskCleanup.xxx] is for activation. Tampering with these services may cause software errors and make your product license invalid. > I suspect that your Spybot might have played with the file? I don't want to disappoint you but, once you've fucked this up, reactivation is -required-.... "Doug" schreef in bericht news:40990c63_3@newsprd01... Attached are the error messages I get when I attempt to open Revit 6.1 or ADT 2005 HELP!!!! Has anyone seen these before? I did my usual HD clean up... I do it once a week. I used both of these programs in the morning and when I re booted after lunch this happened!!! Hope someone has a solution ... Got projects to get out the door!!!! Thanks Doug Attachment not added (too many attachments): "Error 2.JPG"
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
