Doug,
AdskScSrv.exe is the Autodesk License Service for Autodesk standalone license activation. The file in the temporary folder [AdskCleanup.xxx] is for activation. Tampering with these services may cause software errors and make your product license invalid. > I suspect that your Spybot might have played with the file? I don't want to disappoint you but, once you've fucked this up, reactivation is -required-....
"Doug" schreef in bericht news:40990c63_3@newsprd01...
Attached are the error messages I get when I attempt to open Revit 6.1 or ADT 2005 HELP!!!!
Has anyone seen these before? I did my usual HD clean up... I do it once a week. I used both of these programs in the morning
and when I re booted after lunch this happened!!!
Hope someone has a solution ... Got projects to get out the door!!!!
Doug
Attachment not added (too many attachments): "Error 2.JPG"
