Energy Analysis Error - Could not be completed
1 REPLY 1
384 Views, 1 Reply
Using Revit to create simple masses, while I am signed in, I run the energy analysis and keep getting this message - image attached
When I create the same mass in Vasari and run the energy analysis - I do not get this error, the report works.
What else can I try?
1 REPLY 1
Lance.Coffey
If you have not already done so, I would suggest reviewing the following help topic:
Best Practices for Conceptual Energy Analysis
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/2489-Analyze_2489/2515-Conceptu2515...
Also, check if the Project Base Point is far from the origin (greater than 2000 units), as this can cause the error you are seeing.
Lance Coffey
Technical Support Specialist
