Using Revit to create simple masses, while I am signed in, I run the energy analysis and keep getting this message - image attached
When I create the same mass in Vasari and run the energy analysis - I do not get this error, the report works.
What else can I try?
If you have not already done so, I would suggest reviewing the following help topic:
Best Practices for Conceptual Energy Analysis
Also, check if the Project Base Point is far from the origin (greater than 2000 units), as this can cause the error you are seeing.
