Editing wall material to concrete in plan view
13 REPLIES 13
Message 1 of 14
YehudaInbar7952
3306 Views, 13 Replies
In floor plan view how do I make a wall have a concrete texture inside instead of the default (criss cross)?
13 REPLIES 13
Message 2 of 14
in reply to: YehudaInbar7952
Under Wall Properties, Edit>Structure>Materials--change to Concrete for the Cut Pattern.
The "criss-cross" pattern is typically for Concrete Masonry Units ( block), so you should really use a different Wall Type
and name it Cast In-Place Concrete, then specify the correct Material and Fill Pattern.
Message 3 of 14
Thank you. I have made a new wall how you said, changing the material to cast-in place concrete instead of concrete blocks and on the preview for the wall it is perfect but when I draw the line on the floor plan it still has a criss-cross pattern. I have attached a picture where you can see how the wall looks in the properties preview and on the floor plan it  is highlighted.
Thank you,
Yehuda
Message 4 of 14
In Wall Properties, check if there is a Coarse Scale Fill Pattern.
Then in your view, set the Detail Level to Medium or Fine.
Does it now have the Concrete Fill Pattern?
Message 5 of 14
YehudaInbar7952
I set the wall to no pattern and then to concrete pattern and they both still have the criss-cross. It seems like the criss-cross is a default and the only way to change it is to override each individual wall. Thank you, Yehuda Inbar, AIA *Inbar Architecture* * * **2831 Ringling Blvd., Suite E-117 Sarasota, FL 34237 (941) 951-2816 InbarArchitecture@gmail.com www.InbarArchitect.com
Message 6 of 14
Check if the Material is set to "Default Wall"
Go to Manage>Materials then look at Cut Pattern.
See if your wall's Material is really using Default Wall Material--or recheck the Coarse Fill setting under wall properties.
Message 7 of 14
YehudaInbar7952
I went into the materials and the cut pattern is set to concrete. I'm not sure how to check if it is set to default wall. I have attached an image with the walls I am trying to edit just left of the browser. Thank you, Yehuda Inbar, AIA *Inbar Architecture* * * **2831 Ringling Blvd., Suite E-117 Sarasota, FL 34237 (941) 951-2816 InbarArchitecture@gmail.com www.InbarArchitect.com
Message 8 of 14
Check these settings as well.
see attached.
Message 9 of 14
itimot
Hello everyone, I wanted to know how do I configure my Revit Architecture 2013 software so it can save files in previous versions (2012, 2011, 2010)
thank you
Message 10 of 14
in reply to: itimot
Revit is not Backwards Compatable......................
Mike
Message 11 of 14
itimot
so how can i update the 2012 version to 2013 version?
TX
Message 12 of 14
itimot
i mean to update the 2012 software to 2013 software.
thanks
Message 13 of 14
gtoapanta
Hello.
In the Edit assembly- material browser, the Concrete-Cast-in-Place Concrete is not liste as well some of the other material like Ceramic-Tile 4" blue, do you know how to bring in it to the material browser?.
Thank you
Galo
Message 14 of 14
L.Maas
in reply to: gtoapanta
You have to go to your material browser (Manage, Materials) and drag in the proper material to your project.
If the material is not there you can create it yourself by making new material or duplicating existing one and modifying the material parameters (name and how it looks)
Louis
Please mention Revit version, especially when uploading Revit files.
