Duplicate beam
9 REPLIES 9
Message 1 of 10
polyrimutaka
634 Views, 9 Replies
Duplicate beam
I duplicated a beam1 and saved it as, say beam2.
After changing beam2's length I loaded it into project but the length of beam1 also changed followed beam2.
How do I changed beam 2 without affecting beam1?
9 REPLIES 9
Message 2 of 10
vector2
in reply to: polyrimutaka
if you click on a beam and go to element properties>
type properties and duplicate it and name it something
else and change some parameters and ok out of
element properties- you can be sure your new
beam type will show up in the type selector
for beams..
Message 3 of 10
polyrimutaka
Thank you for explanation unfortunately nothing changes.
Let me explain once again:
1. I created a timber joist 150x50
2. I made some changes by modifying the end of this beam to suit its connection with other beams
3. I saved it with the new name, say beam 1.
4. I duplicated beam 1, made only a change in its length, and save it as beam 2.
5. Beam 1's length also changed follows beam 2
I have followed information from help menu also from some online helps but it's still remain same.
Can someone point it out,in detail, what's wrong with my steps?
Regards
Message 4 of 10
vector2
poly-
you said:
"After changing beam2's length I loaded it into project"
what exactly do you mean by "loaded it" ?
Message 5 of 10
polyrimutaka
Hi Vector2,
After changing have been made I pushed button "Load Into Project" under Family Editor panel.
Regards
Message 6 of 10
vector2
poly-
this is a bit confusing but it's interesting..
apparently you have been in the family editor
and you have modified a timber joist..
then- "I saved it with a new name" ?
do you mean while you were still in the family editor
you went to "save as" > "family"? and named it
"Beam 1 .rfa" ?
or did you just load it into the project and
select "overright the existing version"?
you mentioned several things that don't add up
in my mind and i would like to get to the bottom
of this if you are not in a hurry..
Message 7 of 10
polyrimutaka
Vector2,
Thank you for your time for accompanying me.
So far, I have done with two different ways:
1. While in plan/3D views, Click existing beam (beam1) and "edit family" tab.
Once I was in family editor:
- go to "Types" under "Family properties" Tab
- Create new family types (beam2) and press "OK"
- made some changes and load into project
- overright existing version
2. While in plan views, copy existing beam1.
Then click copied beam1 and following steps like I mention in point 1 above.
Regards
Message 8 of 10
Check the length property of the beam. Is it a type property or instance? It
needs to be instance to avoid affecting all beams of the same type.
"polyrimutaka" wrote in message news:6307401@discussion.autodesk.com...
Message 9 of 10
polyrimutaka
Hi Matt,
I have tried with both of them but the results are same!!.
Regards
Message 10 of 10
polyrimutaka wrote:
> Hi Matt,
> Regards
I think you have broken your beam family, to where the length is no
longer parametric at all.
Brian Winterscheidt
LWPB Architecture
Oklahoma City, Oklahoma
