Anything I can do to stop this happening. Split floorplan layout inserted on sheet to compress length to fit.
Section lines appear in both and cant hide in one or the other hence overlapping
Solved by CoreyDaun. Go to Solution.
Can you select the 'duplicate' Sections in one of the Views and then 'Hide by Element'? One can hide an element on a dependent View without affecting the related Views.
