Revit Architecture
*Expert Elite*
CADastrophe
Message 11 of 14 (288 Views)
Re: Doors in angled walls
11-09-2012 12:58 PM in reply to: GRandall
GRandall wrote:
"Yes I can do that but under no circumstances do temporary dimensions function on the non ortho walls."
Seems true - no temporary dimension on a Wall that joins at an angle with another Wall. Revit doesn't always do too well when angles are involved.
What I did below is drag the endpoint of the Walls to make the joint with the angled Wall a right angle, and then the temporary dims become available. However, if you make the dimensions permanent and correct the Walls, the dimensions are lost. There's not much I can contribute here, so I hope this is of some help.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Shawn
Message 12 of 14 (275 Views)
11-09-2012 02:15 PM in reply to: CADastrophe
I have found that using temporary model lines can be a great aid to locating or moving objects that are otherwise difficult to snap to or adjust using normal methods.
SG
*Expert Elite*
Alfredo_Medina
Message 13 of 14 (268 Views)
11-09-2012 03:22 PM in reply to: CADastrophe
Probably a pinned reference plane, perpendicular to the angled wall, could be used to control the distance of the door to a corner, with a dimension.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Contributor
GRandall
Message 14 of 14 (245 Views)
11-12-2012 07:52 AM in reply to: GRandall
Thanks for the suggestions, still a Revet newbie, I'll try them until I find the easiest. Sure seems like there should be some sort of plascement constraint for doors and windows similar to ACA;s for center, offset, etc., since Revit is purported to be the "best".
Wish List anyone
Announcements
Need installation help?
