Door under 1,2m don't cut wall
2 REPLIES 2
317 Views, 2 Replies
Hi all. I have a question related with modelling a door. When I make the door under 1,2 meter hight it doesn't cut the wall in the plan view, only if it is higher then 1,2m. Can some of you help me with this issue. Thank you all.
Tags (3)
2 REPLIES 2
Jason_S
Welcome to the discussion group!!!
The door must be shorter than your cut plane.  There are two ways to change that.  The first, Change your View Depth in the properties palette of the view to something shorter.
The second, would be to create a Plan Region around the door if this is one of a couple locations for this door.  Then you can change the Cut Plane from the Plan Region properties (the menu will look like the View Range menu above) to allow the door to be cut in plan view, therefore showing up as cutting the wall.
Hope this helps you out.
in reply to: Jason_S
Hi again Great, it works perfectly. Many thanks for your help. It was great.
