Can I create a family of doors to be instantiated cut over more than one wall?
I'm using three walls to represent the coating and core wall and realized that to instantiate a door, only one wall is cut.
I tried to change the default template to create families of the door, but I'm not getting success.
Can anyone help me?
Ari Monteiro
Dharma Systemas
Solved by ryan.duell. Go to Solution.
I read somewhere to join the walls first then the door should cut all the walls. I haven't tried it.
You would need to join geometry between the neighboring walls to allow the opening to be automatically cut. You could use a similar approach as in the post below, #9:
http://revitclinic.typepad.com/my_weblog/2009/08/10-wall-tips.html
Otherwise you would need to manually add wall openings to cut the other 2 walls at the door opening.
Thank you,
Welcome to the Discussion Groups!
You cannot join objects in one model with objects in a linked model. Nor can you host a Door in one model on a Wall in a linked model.
You will need to add one or more openings to the Walls in the linked model, and manually coordinate the location of same with the door in the other model.
Thats our current method.
Something more to ask for Christmas to Santa.
Thanks David.
Hi there,
it works well for me, until I use an in place wall. The door won't cut through the in-place wall, even if I join the geometry to the host wall. Same applies vice-versa if the in-place wall is the host.
Anyone got a solution for that? I know I can create another opening in the in-place wall, but it is extra work and would be nice if it behaved in the same way.
I have a slightly different variation of this problem, as the attached PDFs show.
I have created a door family which incorporates the HM frame profile. The jamb depth of the frame is controlled by the thickness of the wall; therefore, the door is fixed to the centerline of the wall. As you can see, the door family only finds the centerline of one of the joined walls, NOT the composite centerline (i.e., the centerline of the overall wall thickness). Any way to make the combined wall fit completely inside the throat of the HM frame? I don't want to resort to linework, due to the sheer number of doors I would have to do that to.
Any insight you could provide would be welcome. Thanks!
You need a door family with adjustable throat width so that you can stretch one or both sides to match the combined walls thickness.
