Directx
10 REPLIES 10
Message 1 of 11
2455 Views, 10 Replies
Directx
I have installed DirectX SDK on my computer. However, every time I open Revit Architecture 2013 I get a message "The DirectX Software Rasterizer cannot be initialized. Please install DirectX SDK to run test properly." The program seems to run properly however.??
10 REPLIES 10
Message 2 of 11
lars-ake.johansson
This sound like it might be a problem with you graphics card and/or graphics driver.
What type of graphics card do you have and what version of the graphics driver are you using?
What OS are you using?
/Laj
Lars-Ake Johansson
Sr. SQA Engineer
Message 3 of 11
in reply to: lars-ake.johansson
Card: GeForce GTX 260M
Driver: NVIDIA ver. 8.15.11.8631
os: Windows 7
Message 4 of 11
lars-ake.johansson
One thing that I do see is that your driver is a bit old, that might be the problem.
Let's start by checking if turning off Hardware Acceleration get's rid of the error:
- Open up the Options dialog
- Select 'Graphics'
- Uncheck 'Use Hardware Acceleraton....."
- Click 'OK'
- Close Revit
-Start Revit again
Did you get the error? If not - I would guess that this is an issue with the driver. Check your system vendors site and/or Nvidia.com for updated driver.
Once installed, turn on HA again and the error will most likely not appear.
Note however that there is currently a know issue with semi-transparent materials with some Nvidia graphics card that you might run in to. We are working with NV on this issue and there will be a new driver posted (I have no ETA on the new driver)....
If you do see an issue with this - turn off HA for now until there is a new driver that fixes this issue is posted.
If you still get the error after tuning off HA and/or the new driver does not help , could you post a journal file here? (or send it to me)
Just start Revit, open a new project and close Revit again.
Grab the last Journal.####.txt (where #### is a sequential number) in:
C:\Users\[your login name]\AppData\Local\Autodesk\Revit\Autodesk Revit Architecture 2013\Journals
Lars-Ake Johansson
Sr. SQA Engineer
Lars-Ake Johansson
Sr. SQA Engineer
Message 5 of 11
Still getting the message. I can't turn on the 3D accelerator. I get the message that I am in software emulation mode and that my video card and driver are not compatible with the program. However I am able to work in Revit 2013. Attached is the journal file
Message 6 of 11
lars-ake.johansson
Could you try something else?
- Browse to: http://www.microsoft.com/en-us/download/details.aspx?id=35
- Download and run dxwebsetup.exe
Start Revit and try to activate HA again.
If you don't get the message,
- could you please post your last Journal-file here as well?
For other reading this post: Please do not install the DirectX SDK - it will not help and it will only install a lot of unnecessary files on your system.
Regards
Laj
Lars-Ake Johansson
Sr. SQA Engineer
Message 7 of 11
The problem of the error message has been solved. However now ray tracing doesn't work well with or without HA.
Message 8 of 11
lars-ake.johansson
Could you please attach the latest Journal ?
/Regards
Laj
Lars-Ake Johansson
Sr. SQA Engineer
Message 9 of 11
Latest Journal is attached
Message 10 of 11
I have 6 GB of RAM. This doesn't appear to be enough for Revit Architecture 2013. This is especially true when I try to use Ray Tracing. I can really only do quite simple projects. Is there a work around?
Message 11 of 11
pcf
Observer
Hi...
I also have the same problem....
my graphic card is Geforce560Ti,
the driver version:306.23
os: windows 7 ultimate x64 sp1
cpu:Intel Q9550
MB:ASUS P5Q3 Deluxe(P45)
RAM: DDR3-1600 16GB(A-DATA)
can any body tell me how to solve this problem?
THX!!
