Revit Architecture
Active Contributor
jbohan
Message 1 of 11 (1,534 Views)
Directx
1534 Views, 10 Replies
05-05-2012 07:15 AM
I have installed DirectX SDK on my computer. However, every time I open Revit Architecture 2013 I get a message "The DirectX Software Rasterizer cannot be initialized. Please install DirectX SDK to run test properly." The program seems to run properly however.??
lars-ake.johansson
Message 2 of 11 (1,508 Views)
Re: Directx
05-07-2012 12:36 PM in reply to: jbohan
This sound like it might be a problem with you graphics card and/or graphics driver.
What type of graphics card do you have and what version of the graphics driver are you using?
What OS are you using?
/Laj
Lars-Ake Johansson
Sr. SQA Engineer
BIM Product Line Group
Active Contributor
jbohan
Message 3 of 11 (1,498 Views)
Re: Directx
05-07-2012 05:54 PM in reply to: lars-ake.johansson
Card: GeForce GTX 260M
Driver: NVIDIA ver. 8.15.11.8631
os: Windows 7
lars-ake.johansson
Message 4 of 11 (1,472 Views)
Re: Directx
05-09-2012 06:50 AM in reply to: jbohan
One thing that I do see is that your driver is a bit old, that might be the problem.
Let's start by checking if turning off Hardware Acceleration get's rid of the error:
- Open up the Options dialog
- Select 'Graphics'
- Uncheck 'Use Hardware Acceleraton....."
- Click 'OK'
- Close Revit
-Start Revit again
Did you get the error? If not - I would guess that this is an issue with the driver. Check your system vendors site and/or Nvidia.com for updated driver.
Once installed, turn on HA again and the error will most likely not appear.
Note however that there is currently a know issue with semi-transparent materials with some Nvidia graphics card that you might run in to. We are working with NV on this issue and there will be a new driver posted (I have no ETA on the new driver)....
If you do see an issue with this - turn off HA for now until there is a new driver that fixes this issue is posted.
If you still get the error after tuning off HA and/or the new driver does not help , could you post a journal file here? (or send it to me)
Just start Revit, open a new project and close Revit again.
Grab the last Journal.####.txt (where #### is a sequential number) in:
C:\Users\[your login name]\AppData\Local\Autodesk\Revit\Autodesk Revit Architecture 2013\Journals
Lars-Ake Johansson
Sr. SQA Engineer
Lars-Ake Johansson
Sr. SQA Engineer
Active Contributor
jbohan
Message 5 of 11 (1,461 Views)
Re: Directx
05-09-2012 11:33 AM in reply to: jbohan
Still getting the message. I can't turn on the 3D accelerator. I get the message that I am in software emulation mode and that my video card and driver are not compatible with the program. However I am able to work in Revit 2013. Attached is the journal file
lars-ake.johansson
Message 6 of 11 (1,451 Views)
Re: Directx
05-09-2012 12:59 PM in reply to: jbohan
Could you try something else?
- Browse to: http://www.microsoft.com/en-us/download/details.aspx?id=35
- Download and run dxwebsetup.exe
Start Revit and try to activate HA again.
If you don't get the message,
- could you please post your last Journal-file here as well?
For other reading this post: Please do not install the DirectX SDK - it will not help and it will only install a lot of unnecessary files on your system.
Regards
Laj
Lars-Ake Johansson
Sr. SQA Engineer
Active Contributor
jbohan
Message 7 of 11 (1,445 Views)
Re: Directx
05-09-2012 01:42 PM in reply to: jbohan
The problem of the error message has been solved. However now ray tracing doesn't work well with or without HA.
lars-ake.johansson
Message 8 of 11 (1,442 Views)
Re: Directx
05-09-2012 01:44 PM in reply to: jbohan
Could you please attach the latest Journal ?
/Regards
Laj
Lars-Ake Johansson
Sr. SQA Engineer
Active Contributor
jbohan
Message 9 of 11 (1,439 Views)
Re: Directx
05-09-2012 02:07 PM in reply to: lars-ake.johansson
Latest Journal is attached
Active Contributor
jbohan
Message 10 of 11 (1,419 Views)
RAM usage
05-10-2012 09:07 AM in reply to: jbohan
I have 6 GB of RAM. This doesn't appear to be enough for Revit Architecture 2013. This is especially true when I try to use Ray Tracing. I can really only do quite simple projects. Is there a work around?
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
