Revit Architecture
Member
30127047
Message 1 of 3 (173 Views)
Accepted Solution
Dimention error
173 Views, 2 Replies
11-26-2013 05:01 AM
It is first time i encoutered quiet an anusual problem with dimentions. Having dimentions rounding set to one decimal place, and hide trailing zero's some dimentions show value like: 7340,999999999999
When I measure the same elements, but dividing it into rooms or grids, all dimentions seem ok, and work without rounding. I can't imagine writing dimentions as text with some "invisible dots" and it is rather uncommon to print final drawings with this kind of dimentioning.
Does anyone found a solution for that problem, was it ever encountered?
Best Regards
*Expert Elite*
Alfredo_Medina
Message 2 of 3 (116 Views)
Re: Dimention error
11-26-2013 07:54 PM in reply to: 30127047
Open the type properties of the dimension, open Units Format. Maybe "Use project settings" is off?
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Member
30127047
Message 3 of 3 (103 Views)
Re: Dimention error
11-27-2013 01:10 AM in reply to: Alfredo_Medina
Nope,
I tried both ways (settings in dimention family and settings in project units).
Anyway the problem got fixed, by update 2, which i luckily installed because of some other error :smileyvery-happy:
Best Regards
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
