Revit Architecture
Active Member
Message 1 of 5 (527 Views)
Dimensioning problems with stud walls
527 Views, 4 Replies
11-09-2012 08:38 AM
Hello there
This is a very complicated thing to explain, but I'll have a go here.
I am having problems dimensioning internal walls with Revit 2013. Horizontally I have no issues, but when trying to dimension vertically from anywhere to the face of the core of a stud wall.
Basically what is happening is that Revit won't recognise the core of a wall from its smallest side (wraps at ends).
Please have a look to the attached file, For example, if I have a 63mm stud wall with a 15mm layer of plasterboard finish to either side, I will be able to put dimensions alongside the faces of the core in the long side of the wall, but I can't locate a dimension showing the 870mm lenght because the face of the ends of the wall won't be recognised by the dimension command.
Any ideas / solutions?
Alfredo_Medina
Message 2 of 5 (518 Views)
Re: Dimensioning problems with stud walls
11-09-2012 09:15 AM in reply to: angelica.rodriguez
http://screencast.com/t/RW910QhM
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
CADastrophe
Message 3 of 5 (503 Views)
11-09-2012 09:30 AM in reply to: Alfredo_Medina
I believe that Angelica is referring to dimensioning the faces as per this image. They don't seem to be selectable as valid faces for a Dimension.
Alfredo_Medina
Message 4 of 5 (495 Views)
11-09-2012 09:53 AM in reply to: CADastrophe
Oh, sorry. Yes, for that, the only solution I think, is a locked reference plane, then dimension to the ref. plane to another ref. plane on the other side. Different video. :smileyhappy:
http://screencast.com/t/v45V6Pmcoak
Active Member
Message 5 of 5 (452 Views)
11-12-2012 01:27 AM in reply to: Alfredo_Medina
That's very good, thank you very much for that Alfredo. Here in the office we were drawing model lines and dimensioning to them, but if our wall moved or changed the dimension wouldn't change.
Thank you very much for your help.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
