Revit Architecture
Message 1 of 11 (1,019 Views)
Dimensioning 3D drafting views
1019 Views, 10 Replies
04-09-2012 11:54 AM
Anyone know if it is possible to create proper dimensions for 3D isometric drafting views? In AutoCAD I could set an oblique angle for a dimension but in Revit there is no setting. I can only dimension 3D model views.
See attached PDF for example.
Employee
loboarch
Message 2 of 11 (1,006 Views)
Re: Dimensioning 3D drafting views
04-09-2012 12:55 PM in reply to: paul
Ther is no oblique dimension style in Revit.  You could do this kind of view as a 3d model view with elements hidden, a section box and the line work tool.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Message 3 of 11 (999 Views)
04-09-2012 01:09 PM in reply to: loboarch
I thought so. Unfortunately if you want to reuse the detail across multiple project it means recreating it each time. :smileysad:
Valued Mentor
vector2
Message 4 of 11 (874 Views)
04-27-2012 11:15 PM in reply to: paul
Possibly this is what you are looking for.
parveen.revit
Message 5 of 11 (837 Views)
04-29-2012 10:08 PM in reply to: paul
it's not feasible in revit drafting view.
intersting point to raise though...
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
*Expert Elite*
Alfredo_Medina
Message 6 of 11 (816 Views)
04-30-2012 09:47 AM in reply to: parveen.revit
The tip shown by Vector about changing the workplane to apply dimensions in 3D views is useful, but it does not apply to drafting views (the topic in this thread) since a drafting view is just a flat drawing with no workplanes.
In a drafting view, you can use the regular Aligned dimension tool to fully dimension the drafting view, even if it is an isometric kind of view. The only missing feature would be the "oblique" angle, but apart from that, you can dimension everything.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Mentor
vector2
Message 7 of 11 (762 Views)
04-30-2012 05:23 PM in reply to: Alfredo_Medina
Alfredo_Medina wrote:
"drafting views (the topic in this thread)"
Are you saying if that drawing I posted on that Revit sheet came
from AutoCAD that it would not be a drafting view? (the topic of
this thread). Where does it have to come from to quality as a
drafting view? Remember they only asked for dimensions on
a drafting view.
Valued Mentor
vector2
Message 8 of 11 (757 Views)
04-30-2012 05:49 PM in reply to: parveen.revit
parveen.revit wrote:
"it's not feasible in a revit drafting view."
That's correct but they didn't say anything about doing
this in a revit drafting view.
parveen.revit
Message 9 of 11 (740 Views)
05-01-2012 02:04 AM in reply to: paul
Revit is different than AutoCAD and this is one the functionalily (oblique dimensions) which Revit doesn't have.
*Expert Elite*
Alfredo_Medina
Message 10 of 11 (721 Views)
05-01-2012 05:29 AM in reply to: vector2
Not true. The original post in this thread begins with "Anyone know if it is possible to create proper dimensions for 3D isometric drafting views?"
A drafting view is flat, even if it shows a "3d" representation of an object. Therefore you cannot dimension that drafting view by setting workplanes because it is not possible to set a different workplane in a drafting view.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
