- The survey points come with a True North orientation and they represent absolute values (conected to a world system)
- The Project North is an easy way to rotate the building so as its grids to be horizontal and vertical in order to allow a quick design process - it works with relative values...
People that worked in Autocad understand it better : WCS versus UCS
In practice I use two methods:
1. when I have the project in an advanced phase of work and I want then to insert a Toposurface.
- in Site Plane view, True North, insert Toposurface. The building will appear as in Project North (horizontal-vertical orientation).
- Select the Project Base Point (use filter in order to separate it from the Survey Point Internal), unclip it and move it at a grid intersection (or a corner of the building). Draw then, a Reference Plane through the grid intersection at an angle the building is orientated on site.
- Measure the angle with horizontal (angular dimension) .Click on Project Base Point and at Align to True North put the measured angle value.The whole will rotate .
- Now , select only the Toposurface and Rotate back with the measured angle ...
2. I begin with the Toposurface- no project yet...
- make the Toposuface
- draw in Site Level (True North) a Model Line with the desired orientation of the building
- in Level 1 (Project North) Manage >Rotate Project North >Align Selected Line ...the Model Line will snap to horizontal or vertical ...
- reasign the Elevation Views
Constantin Stroescu
