Hi All,
This is another question on just how much detail is feasible in a building model without bogging down the computer processes. My company manufactures Architectural panels for the exterior faces of buildings. We're moving into the wild and wonderful world of 3D and as we develop Revit families for our products, we question just how much detail we should build into them. We know about the level of detail (fine, coarse...) but i'm talking about more than that.
Years ago it was suggested to me that we keep the model as simple as can be while still including as much information necessary to address interferences and such. Then i was told to let Revit cut the section/detail and to superimpose a 2D drawing to impart the details that were not included in the model.
Does this make sense and is this a viable way to proceed or should we put all the detail in the model?
All other suggestions are appreciated.
TIA,
Sal
Solved by BIMologist_. Go to Solution.
I think that you need to consider the requirements of your models & drawings, and then work back to which tools to use.
I think of BIM as a specification and coordination tool. The information you put into a Revit model is the information you need to schedule out, or the information that needs to be coordinated with the other consultants, or the other trades on site.
Revit is not intended to be a manufacturing tool. If you are tempted to put manufacturing information into your Revit model it will definitly be too 'Heavy'.
It may be that your soloution isn't within one CAD product. E.g. You might use Revit for coordination the panelling design and scheduling of panel sizes and then use AutoCAD or Inventor for manufacturing documentation.
Bimstore has some good guidance documents:
You're on the right path. Model the basic geometry of your wall panel and parametricize it (length, width, depth, material, etc.). Then create separate detail component families and nest them into the appropriate wall panel family view (i.e. section detail in either left or right view, plan detail in plan view, etc.) and then hide the modeled geometry (if necessary).
Hi Nauman,
Thanks for your input to this nubee.
Can you please be more specific about "not DWG files please, but converted to Revit lines"? Is this as simple as importing an DWG file and saving as "Revit lines"?
Thanks again.
Sal
Thanks Ross,
This is what i had in mind. Now to the task of explaining it to the higher-ups who, for their own safety, do not even have CAD on their computers.
Sal
