hi
I for See Protrusion Top floor Linework tool I used.
But the By now I want to It disappears Do.
But the I do not know how to do Do.
Solved by constantin.stroescu. Go to Solution.
A simple way to do this is to Duplicate the View with Detailing. The copy will loose all the overrides by view ( as Linework ) but will keep all the other informations of the project. Then , delete the old view (with override) and rename the new view with its name....
Constantin Stroescu
hi
Thank you
Yes, it is a simple the method.
But features like on / off, is not?
Thank you
