Deployment - Batch Script
3 REPLIES 3
cmarks
1220 Views, 3 Replies
I'm trying to use the sample script for single network license located at - Script
The script says it's for AutoCad even though it's located under the Revit section of the Wiki. Does anyone know how I can modify this to work with Revit? Something like substitue "acad" with "revit," maybe?
Thank you very much!
3 REPLIES 3
DannyHubbard
in reply to: cmarks
Yes this works with Revit, only thing you really have to change is the ACAD: to RAC2013: then your install directory.
Something like:
<mediaDriveLetter>\setup.exe /t /qb /language <lang> /c RAC2013: INSTALLDIR="%programFiles%\Autodesk\Revit Architecture 2013" ACADSERIALPREFIX=<SerialPrefix>ACADSERIALNUMBER=<SerialPostFix> ADLM_PRODKEY=<ProdKey> ADLM_EULA_COUNTRY=<eula_lang> InstallLevel=5 ACADSTANDALONENETWORKTYPE="3" ACADLICENSESERVERTYPE="Single Server License" ACADLICENSETYPE="Network License" ACADSERVERPATH="<FlexLicenseServer> 000000000000
Danny
Danny Hubbard
QA Analyst
cmarks
in reply to: DannyHubbard
Thanks for replying!
I made the suggested changes and I recieved the same results. I've attached the log files but here is the part that fails -
MSI (s) (4C:24) [13:39:18:758]: Product: Revit Architecture 2013 - - Error 1606.Could not access network location Revit Architecture 2013\.
MSI (s) (4C:24) [13:39:18:758]: Note: 1: 1606 2: Revit Architecture 2013\
Action ended 13:39:18: CostFinalize. Return value 3.
Action ended 13:39:18: INSTALL. Return value 3.
I tried manually creating the program files directory then running the batch file but that didn't work. Any other suggestions? Thanks!
DannyHubbard
in reply to: cmarks
So your command string should look like the following, with the correct serial numbers and license server name.
\\192.168.1.105\InstallPoint\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\setup.exe /t /qb /w /language en-us /c RAC2013: INSTALLDIR="%programFiles%\Autodesk\Revit Architecture 2013" ACADSERIALPREFIX=341 ACADSERIALNUMBER=12345678 ADLM_PRODKEY=240E1 ADLM_EULA_COUNTRY=US InstallLevel=5 ACADSTANDALONENETWORKTYPE="3" ACADLICENSESERVERTYPE="Single Server License" ACADLICENSETYPE="Network License" ACADSERVERPATH="licensesrv 000000000000"
Are you running this through a batch file? Did you right click on the batch file and use the Run as Administrator option?
Danny
Danny Hubbard
QA Analyst
