Demo Ceiling Tile
5 REPLIES 5
arkman
7096 Views, 5 Replies
Demo Ceiling Tile
I have a area of 2x2 lay in ceiling that I would like to show as being demolished. I would like the grid to be dashed. I cant seem to figure it out. Any suggestions?
Thanks!
5 REPLIES 5
in reply to: arkman
Ceilings are different than other components and when you demolish the
ceiling, it doesn't change to dashed appearance like other entities. (The
same is true with changing the visibility graphics of ceilings, as you can't
change it to a dashed appearance.) The only thing that would change to a
dashed appearance is the outline. The lay in ceiling really isn't composed
of lines 2' apart, but is the result of a fill pattern.
The 2'x2' lay in ceiling contains a layer with the material of Acoustical
Ceiling Tile 24" x 24". This material uses a surface pattern of Ceiling
24x24, which is a Model pattern fill defined in the Revit.pat file. Since
the fill pattern defines the actual solid line appearance of the ceiling,
this is what keeps the ceiling tile from appearing dashed.
You will need to use the above information to get the ceiling to be dashed
following these steps:
- Create a new fill pattern for 24"x24" demolished ceiling tile using dashed
lines.
- Create a new material for demolished ceilings and using that new fill
pattern.
- Create a new Ceiling type that uses that new ceiling material as the
layer.
- After demolishing your ceiling, change the ceiling type to be that new
ceiling type so that it appears as dashed.
I hope that helps. 🙂
Doug
http://www.dougbowersconsulting.com
http://aectechtalk.wordpress.com
"Arkman" wrote in message news:6258504@discussion.autodesk.com...
Thanks!
arkman
in reply to: arkman
Thanks doug. That worked. I just had to figure out how to make a new fill pattern. It wasn't as hard as I thought, but I guess I was only making some straight lines.
Thanks again!
in reply to: arkman
You're welcome. I'm glad it helped. 🙂
"Arkman" wrote in message news:6260320@discussion.autodesk.com...
straight lines.
Thanks again!
andrewvonlohr3761
in reply to: arkman
This information has been really helpful however I am still having issues with creating a specific Demo Ceiling Plan. I have created a ceiling plan that is for the phases "Existing + Demo" and a new ceiling grid type with a dashed fill pattern. When I create the ceiling as existing everything shows up fine however when I change the Phase Demolished to Demolished the ceiling pattern will not show up. Any direction with this issue would be appreciated. Thank you for your time.
arkman
in reply to: arkman
I'm not sure if I totally understand your problem but my only thought is make sure that you have a separate ceiling for the ceiling you will demo. Make sure that you say what phase it is going to be demo'd and then make sure you have that phase being displayed properly. Sorry I couldn't be more help. I am really new to Revit myself.
