Revit Architecture
New Member
mmau
Message 1 of 7 (7,447 Views)
Default Template File Invalid
7447 Views, 6 Replies
06-26-2011 12:04 PM
when I start Revit it show me this message, I cant find any component in my library components, any solutions?
It says:
"The default template file you have specified does not exist:"
Employee
ryan.duell
Message 2 of 7 (7,403 Views)
Re: Default Template File Invalid
06-29-2011 08:45 AM in reply to: mmau
I would verify you have installed the content for Revit; under R > Options > File Locations, verify the default template file location. It is installed at the following location by default:
C:\ProgramData\Autodesk\RAC 2012\Templates\US Imperial\default.rte
To install content packs in Revit 2012 you need to do so in the Control Panel > Add/Remove Programs.  Here is a post with the process below:
Installing Content for Revit 2012 products
Thank you,
Ryan Duell
Revit Clinic
@revitclinic
New Member
kirstin.donaldson
Message 3 of 7 (5,170 Views)
08-15-2012 07:49 PM in reply to: ryan.duell
Hi there
I am having the same problem (I've downloaded Revit Architecture 2012 for students) and I get an error message first saying "the default template file you have specified does not exist: C:\ProgramData\Autodesk\RAC 2012\Templates\Australia\DefaultAUSENU.rte"
But when I look in the RAC 2012 folder it's empty...  I've done a search on templates and there don't seem to be any loaded.
when I close that error message I get one that says: "the path you have specified for the default family template files is invalid"
I have had IT guys looking at this but we're all a bit lost as to what to do.
I've uninstalled it and reinstalled it 3 times to no avail.  Can you please help???  I have assignments due and I can't even start them yet!
thanks
New Member
romekarthi
Message 4 of 7 (1,489 Views)
12-07-2013 01:24 AM in reply to: mmau
hi,
i have problem on my revit , i  attached it...
it not opening at all..
while i see through internet , i see this thing
i dont any location like this
"c:\ProgramData\Autodesk\RAC 2012\Family Templates\English_I   or
c:\ProgramData\Autodesk\RAC 2012\Family Templates\English"
 mine is windows 7 ultimate..
 please help , i have project work to do....
New Member
romekarthi
Message 5 of 7 (1,483 Views)
12-07-2013 01:42 AM in reply to: mmau
while start working i got error msg..
help me to out...
Valued Mentor
gh_ar
Message 6 of 7 (1,470 Views)
12-07-2013 07:56 AM in reply to: romekarthi
hi romekarthi
In the Options dialog,Choice Use Hardware Acceleration Deactivate.And Then close Revit And again open.
Valued Mentor
gh_ar
Message 7 of 7 (1,463 Views)
12-07-2013 09:43 AM in reply to: romekarthi
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
