Default Template File Invalid
6 REPLIES 6
mmau
13618 Views, 6 Replies
when I start Revit it show me this message, I cant find any component in my library components, any solutions?
It says:
"The default template file you have specified does not exist:"
6 REPLIES 6
ryan.duell
in reply to: mmau
I would verify you have installed the content for Revit; under R > Options > File Locations, verify the default template file location. It is installed at the following location by default:
C:\ProgramData\Autodesk\RAC 2012\Templates\US Imperial\default.rte
To install content packs in Revit 2012 you need to do so in the Control Panel > Add/Remove Programs.  Here is a post with the process below:
Installing Content for Revit 2012 products
Thank you,
Ryan Duell
Hi there
I am having the same problem (I've downloaded Revit Architecture 2012 for students) and I get an error message first saying "the default template file you have specified does not exist: C:\ProgramData\Autodesk\RAC 2012\Templates\Australia\DefaultAUSENU.rte"
But when I look in the RAC 2012 folder it's empty...  I've done a search on templates and there don't seem to be any loaded.
when I close that error message I get one that says: "the path you have specified for the default family template files is invalid"
I have had IT guys looking at this but we're all a bit lost as to what to do.
I've uninstalled it and reinstalled it 3 times to no avail.  Can you please help???  I have assignments due and I can't even start them yet!
thanks
romekarthi
in reply to: mmau
hi,
i have problem on my revit , i  attached it...
it not opening at all..
while i see through internet , i see this thing
i dont any location like this
"c:\ProgramData\Autodesk\RAC 2012\Family Templates\English_I   or
c:\ProgramData\Autodesk\RAC 2012\Family Templates\English"
 mine is windows 7 ultimate..
 please help , i have project work to do....
romekarthi
in reply to: mmau
while start working i got error msg..
help me to out...
GHASEM_ARIYANI
in reply to: romekarthi
hi romekarthi
In the Options dialog,Choice Use Hardware Acceleration Deactivate.And Then close Revit And again open.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
hi go to Likes: Componnents: http://www.aryaahora.com/revit/revitarchitecture/24--componnet-revit-architecture.html Templates: http://www.aryaahora.com/revit/revitarchitecture/23--revit-architecture.html
Rail Community
