Revit Architecture
Active Member
jacksonfung3916
Message 1 of 2 (592 Views)
Data in the File is corrupt and needs to be manually recovered.
592 Views, 1 Replies
01-09-2013 06:59 AM
My project file is corrupted.  I try to recover the project via the central and local backup folder, however the backups are also corrputed.  I also try to look for backups via the Journals folder, and again the same thing happen.  I know Autodesk can recover such damaged file, but I have no idea where I can get the help.  Can anyone give me some direction?  Thanks,
*Expert Elite*
LisaDrago
Message 2 of 2 (568 Views)
Re: Data in the File is corrupt and needs to be manually recovered.
01-10-2013 12:46 PM in reply to: jacksonfung3916
If you are on subscription - you can go through the subscription center and put a ticket in to Autodesk. Or you can contact your reseller and have them do it.
I will see if I can get some help for you here...
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
