My project file is corrupted. I try to recover the project via the central and local backup folder, however the backups are also corrputed. I also try to look for backups via the Journals folder, and again the same thing happen. I know Autodesk can recover such damaged file, but I have no idea where I can get the help. Can anyone give me some direction? Thanks,
If you are on subscription - you can go through the subscription center and put a ticket in to Autodesk. Or you can contact your reseller and have them do it.
I will see if I can get some help for you here...
LD
