Hi
I am new to Revit and need to import some dwg files.
I cerate a empty project and try to import, all files (except one which import fine) show these error messages.
They dont show up in the Floor view. Only one dwg show up uppon import both in the Floor view and 3D view.
All other files show only up when "current view only" is selected but in this case dont show up in the 3d view or when imported having the 3D view active in which case they dont show in the Floor Plan view.
Dimi
Hi
thanks for the reply. No I am imporitng them one at a time. They should only have 3D info on them. We want to use Revit to attach Bim info.
I am attaching some dwg files I am having problems with. The taco.dwg always shows up. The other two show up only in the 3D view. If you use the Import units to Auto-Detect they come in really small, therefore I override them to meters. But again they sho up only in the 3D view.
I am just learning revit, I am not sure if they just are placed out of view. But I relly zoomed out/in without success on the Level Views.
Thanks in advance
Dimi
