HI
I am using revit 2014, in door option i have only single-flush door, how can i find double flush door,
2ndly i saw tutorial he putt window in the elevation after this he can chnage the size of window
when i putt the window its fixed and i cant chnage th size ...
THanks & Regards
Solved by constantin.stroescu. Go to Solution.
I am sending you an image file for your door query. Please find the attached file.
For your window query, every window family is parametric in Revit Default. So you can change any time its Width & Height. Please check thoroughly the Window Family.
Thanks & regards,
Subhradeep Sen
Kolkata
India
2.
Your Name
Dear Sir,
i got the solution for the door butt i am still confused how to adjust the size of window and how can i make Windows with Instance Parameters instead of Type Parameters....
Thnaks & Regards
I've made a rough recording with Type vs Instance Window Families...
https://chronicle.autodesk.com/main/details/7d3641df-db02-4bad-95c5-7733037cf851
In attachment you can find two windows Families : one Type and one Instance.....
Your Name
