Revit Architecture
Valued Contributor
wantono
Message 1 of 3 (361 Views)
DEFAULT 3D IS HIDDEN
361 Views, 2 Replies
11-19-2012 04:13 PM
Revit 2011:
My 3D default view now shows nothing! I have a large project that has worked fine until recently. The camera shots still work and all my drawings are in tact, I just cannot look at my building in 3D orbit any more because the screen is blank. Tried ZA, Zoom to fit, nothing hidden. Any ideas?
Valued Contributor
charlv
Message 2 of 3 (341 Views)
Re: DEFAULT 3D IS HIDDEN
11-20-2012 06:47 AM in reply to: wantono
HI,
Try deleting the 3D view and re-creating the 3D view by clicking the 'House' icon to create a new Default 3D view.
Charl
Valued Contributor
wantono
Message 3 of 3 (313 Views)
11-21-2012 07:54 PM in reply to: charlv
Fixed it! After I went to View Graphics and turned off the imported CAD links from a metal building supplier I could see my Revit model! I have had this problem once before when I was tracing a CAD file (DWG) with Revit and then could not see section cuts because apparently the CAD had some 3D to its own file that was blocking Revit. After I turned off the CAD file I could see the Revit. Did not try deleting the default 3D viewport, but it may have worked. Hope this helps others. Anyone ever had this happen to them?
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
