DB link not functioning
3 REPLIES 3
kishore152
440 Views, 3 Replies
Hi all,
I could not export the revit data using DB link as nothing is getting highlighted to click on next.
Is there anything extra that I need to install apart from MS Access or should I follow a specific procedure before I go to addins.
Please suggest.
Please find the attached screenshot for the problem I encountered.
3 REPLIES 3
parveen.revit
in reply to: kishore152
i guess you installation is good.
You just need to create a database (MS Acess database) which you can link to.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
kishore152
Thank you for replying,
But actually you can find in the attached screenshot of my first post, that there is no option to select any database though I create one.
So, may be there is some other reason that I could not figure out.
Hello!!!
You can use  "ODBS" export  and SQL Server
This link has infomation about your problems
http://forums.autodesk.com/t5/Autodesk-Revit-MEP/Revit-database-link/m-p/3596476/highlight/true#M168...
and if you will translate my post http://aelunin.blogspot.com/2012/06/revit-db-link-revit-db-link.html#more
I think it will help))))
Tags (1)
