Is there any tool by which we can create opening for MEP service. Our model are in Autodesk Fabrication CAD MEP and Revit platform. Our main objective is that can we attain cut opening among different platforms like an solid wall (created in AutoCAD) with a Revit MEP Pipe/Duct.
Thanks in advance!
Solved by AJA14. Go to Solution.
Thanks for your feedback.
We are already using this add-ins. But here we can not cut openings from multi disciplinary softwares.
Thanks. We are using both the tools (Cut Opening Pro & Cut Opening LT)
For an example we have created the Architecture model in Revit interface and MEP model in other software (i.e. Autodesk Fabrication CAD MEP) interface. Now we will create the MEP opening in the Architecture wall. Is it possible in any software.
Thanks for your suggestion. Primarily our objective is to perform cut opening amoung cross platform softwares. Can it be really possible using API/Add-ins or you can suggest any other mechanism to perform the same?
