Customizing hatch
3 REPLIES 3
andrea_pontiggia
327 Views, 3 Replies
Customizing hatch
You can assign a pen width to the lines of a hatch?
thanks
Andrea
3 REPLIES 3
When you create or modify a filled region (hatch) - you can control the pen. I have an image attached for reference.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
I referred to hatches automatic assigned directly to the materials, which appear for example when it dissects an element. thanks
Andrea
you know - that is a really good question - I did some looking and I am not finding anything specific to control it..
What I did find - under VV or VG you can control the pattern but not the pen weight. Image attached
but on others you can control the pen weight. image attached.
I looked under the object styles and was not able to find anythng there that corresponds to the patterns or lines.
So very interesting question - maybe someone else has some ideas!
LD
