I am trying to customize my Assembly Code file by modifying the UniformatClassifications.txt file. Specifically, I am trying to get more level 4 codes, and am trying to use a file I have used in prevoius versions of Revit. In Revit Architecture 2015 I keep getting the "The classification fode xxxxxx doesn't match level '4' and parent code xxxxx. Is the required syntax for this file available anywhere?
Autodesk does not recommend or support edits made to the Uniformat data file (UniformatClassifications.txt) located in %APPDATA%\Autodesk\Revit\<product name and release>. (from http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-5900EA95-9702-4054-A849-C0A70EABB2D1)
See this link for similar issue that mentions a possible future solution: http://forums.autodesk.com/t5/Revit-API/Custom-UniformatClassification-file/td-p/3740268
Thank you posting.
We have developed an application for managing the Uniformat classifications for Revit models and use it in our specification applications called e-SPECS (www.e-specs.com). We link the Revit BIM models to the construction specifications using the Assembly Codes. You can see the On-Line Demo on our website and if you'd like more info just let me know.
- Seamus
