Revit Architecture
Member
blawlor
Message 1 of 2 (237 Views)
Custom Wall Assembly Tag
237 Views, 1 Replies
11-01-2013 02:13 PM
Hi all,
Im working on creating all of our common AutoCAD annotation symbols in revit.
For section details we use a wall asembly tag that wraps the thickness of the wall, and its set up so we pull the arrows to match the width of the assembly. (see attatchment)
Im struggling to find a way to make this work in Revit as well, either by automatically adjusting to the width of the assembly we are tagging, or even by just pulling the arrows like we did in autocad.
Any suggestions or answers would be greatly appreciated
Product Support
fernanda.firman
Message 2 of 2 (173 Views)
Re: Custom Wall Assembly Tag
11-08-2013 08:47 AM in reply to: blawlor
Thank you for posting!
Unfortunately it is not possible to create an arrow tag that adjusts to the wall thickness.
I understand that this may be important to you, so I am including the following link. It is setup for you to submit feature requests, or feedback, directly to our development team:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
