Custom Revision Schedule
1 REPLY 1
bmwm3owner
622 Views, 1 Reply
Hello.
I need to customize my revision schedule so that it appears a certain way in our titleblocks. The titleblock was provided by the owner and their revision table is built from the bottom up and right to left. I know you can sort a revision schedule from bottom to top, but I am not sure how to split it to continue to the bottom right after revision #4.
I initially thought I could create 8 revision schedules, placing each schedule for each line in the titleblock, but there is no filter option to filter out unwanted numbers. I can use any and all advice on how to bulid a bottom up, right to left revision schedule.
1 REPLY 1
LisaDrago
in reply to: bmwm3owner
At this time there is no way to split the schedule. I have a lot of clients that need this but it is not possible.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Rail Community
