Custom Cladding Panel
7 REPLIES 7
Message 1 of 8
daverob88
16369 Views, 7 Replies
Is it possible to create a custom Cladding Panel in Revit Architecture, whereby the panel shows elements of both solid extrusion and void extrusions?
7 REPLIES 7
Message 2 of 8
ryan.duell
in reply to: daverob88
Yes you could create this as a wall based or in-place component family.  Another alternative would be to use a curtain wall.  I have included some resources below:
In-Place Elements
Video
Curtain Wall
Thank you,
In-Place Elements
http://docs.autodesk.com/subscription/REVIT/2011/ENU/filesUsersGuide/WS1a9193826455f5ff-4f6d1f1d11d2...
Video
http://www.youtube.com/watch?v=UNig_5t-LP0
Curtain Wall
http://autodesk-revit.blogspot.com/2007/08/custom-curtain-wall-panels.html
http://www.youtube.com/watch?v=Cslf3jkOMV0
Thank you,
Ryan Duell
Message 3 of 8
in reply to: ryan.duell
Hello everyone,
I take the topic to ask you for help on creating curtain wall with gable.
My example is in the attached file revit.
I would like to create a pinion on my curtain wall and a hangar door panels which cuts 2 and a half panel.
Somebody can help me solve this problem please?
Message 4 of 8
cbcarch
You can use Edit Profile and change the shape of the curtainwall to make the gable. Highlight/select the edge of the curtainwall and Edit Profile.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 8
arunag
You have created a Panel family without making it parametric using profie family, hence any changes applied , it loses its relation & doesn't fit forcing panels to get deleted. Instead if you choose a mullion family of the shape shown in plan with solid panels, matching the sizes, offsets,spacing etc it gives the same result & you can also attach to your roof to get gable shape or even edit profile the shape of wall. Attached a revit file for your reference.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
Message 6 of 8
Hi, could you possibly post an updated link for the In-Place elements as the link no longer works
thanks
lewis
Message 7 of 8
David_W_Koch
Welcome to the community!
I am not sure if this article (and the two linked subarticles) in the Revit 2016 Help are the equivalent to the previous link, but it may be a starting point for you.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 8 of 8
in reply to: David_W_Koch
Thanks, thats given me somewhere to start looking.
