Is it possible to create a custom Cladding Panel in Revit Architecture, whereby the panel shows elements of both solid extrusion and void extrusions?
Yes you could create this as a wall based or in-place component family. Another alternative would be to use a curtain wall. I have included some resources below:
In-Place Elements
Video
http://www.youtube.com/watch?v=UNig_5t-LP0
Curtain Wall
http://autodesk-revit.blogspot.com/2007/08/custom-curtain-wall-panels.html
http://www.youtube.com/watch?v=Cslf3jkOMV0
Thank you,
Hello everyone,
I take the topic to ask you for help on creating curtain wall with gable.
My example is in the attached file revit.
I would like to create a pinion on my curtain wall and a hangar door panels which cuts 2 and a half panel.
Somebody can help me solve this problem please?
You can use Edit Profile and change the shape of the curtainwall to make the gable. Highlight/select the edge of the curtainwall and Edit Profile.
You have created a Panel family without making it parametric using profie family, hence any changes applied , it loses its relation & doesn't fit forcing panels to get deleted. Instead if you choose a mullion family of the shape shown in plan with solid panels, matching the sizes, offsets,spacing etc it gives the same result & you can also attach to your roof to get gable shape or even edit profile the shape of wall. Attached a revit file for your reference.
Hi, could you possibly post an updated link for the In-Place elements as the link no longer works
thanks
lewis
Welcome to the community!
I am not sure if this article (and the two linked subarticles) in the Revit 2016 Help are the equivalent to the previous link, but it may be a starting point for you.
