Hi guys,
I'm pretty new on the forum, I've tried searching all over the forums and watching different youtube videos but I can't seem to find the answer for my question.
I need to make a roof on a curved building. But when I try with Roof by Footprint it just brings up the error "Can't make footprint roof."
I hope you can help me 🙂
Hi
Welcome to the Forums.
You Roof By Extrusion tool to create a overall plan and The Vertical Opening Tool and Cut off extra parts.
and or Mass.
You can make a curved Roof by Footprint with 4 slopes but not with 2 slopes, because it will give you an error message....
I propose a trick.:- Make a Roof by Footprint with 4 slopes and cut it with voids:
Another method could be a Component- sweep :Component> Model in Place> Family Category and Parameters > Roofs > Name >Sweep - draw the curve as path and the normal section of the roof as Profile
Another one could be Roof by Face applied to a mass element that you have to create in Mass Model in Place ( or made in Mass editor)
I'm afraid that Roof by extrusion won't work because extrusion is after a straight line not a curved one.....sweep follows a curve...
Constantin Stroescu
It would be useful to specify what kind of roof you need to create. Your original post just says "I need to make a roof on a curved building."
If you want to conect a roof made by sweep ( Component > Model in Place > Family Category and Parameters > Roofs >Sweep ) with another roof made by other method ( let's say by Footprint ) you will be able to do it using Join Roof function...The condition of joining is that both entities to be defined as roofs..
Constantin Stroescu
