Revit Architecture
Distinguished Contributor
Message 1 of 9 (1,109 Views)
Curtain wall mullion bug?
1109 Views, 8 Replies
04-01-2011 07:01 AM
We've been using Kawneer's mullion profiles and detail items as well as creating our own for the past 2 years, but we've begun noticing that some mullions' detail items will flip when the section view is looking one way versus another.  The mullion profile is displayed properly though so the view isn't flipping the entire mullion family.
We're running Revit 2011 x64, and haven't noticed this problem previously.
Attached is one of the culprits.  Has anyone else had similar issues?
Thanks.
- Alex
New Member
jcvedder1
Message 2 of 9 (988 Views)
Re: Curtain wall mullion bug?
12-14-2011 08:15 AM in reply to: Jazzster11
I've been experiencing this also, and its extremely frustrating.  I've had some success copying a curtainwall with the detail lines of the mullion displaying in the correct orientation and it working in other section views.  This itself is really annoying and removes references of the wall you are trying to replace/fix.  I haven't found a way to fix the problem the 'right' way.  Anyone else?
Alfredo_Medina
Message 3 of 9 (968 Views)
12-14-2011 09:22 PM in reply to: jcvedder1
Can you post an image showing how the detail component looks wrong? I could not see any problem here.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Message 4 of 9 (948 Views)
12-19-2011 12:36 PM in reply to: Jazzster11
Unfortunately it's been too long since I posted the original message to still have examples of the problem showing up in our project, but I believe the detail item referenced within the mullion profile family would "flip" either vertically or horizontally in a few views.  The weird thing was that cutting a new section or creating a new plan view often fixed the problem.
We couldn't keep recreating views that were fully developed so I think we hid the projection lines of those objects and simply placed the correct detail item on top within the view.
I don't remember running into this problem since we switched to Revit 2012.
Thanks.
- Alex
Alfredo_Medina
Message 5 of 9 (945 Views)
12-19-2011 12:53 PM in reply to: Jazzster11
That must be. I tried to reproduce the error, using RAC2012, but it did not happen.
New Member
rsanz85
Message 6 of 9 (883 Views)
01-24-2012 07:41 AM in reply to: Jazzster11
Sorry to bump an old thread, but we have been experiencing this issue at our office as well.  Very frustrating and requires jumping through hoops to get the mullion to display correctly in our sections and details.
See attached for example of this issue.
Active Member
AdamHamilton
Message 7 of 9 (790 Views)
05-01-2012 08:52 AM in reply to: Jazzster11
i have the same problem... all elements are pure revit...tried locking down, ref planes. nothing.
RAC2012 all updates
Alfredo_Medina
Message 8 of 9 (764 Views)
05-02-2012 07:16 AM in reply to: AdamHamilton
Is it possible to post a small portion of the file, when this error is happening? As I said before, I tried to reproduce the problem, but everything worked as expected. Having the actual file would help.
Active Member
AdamHamilton
Message 9 of 9 (702 Views)
05-22-2012 09:57 AM in reply to: AdamHamilton
I found the solution to my problem. the mullion was part of a curtain wall system hosted to a Mass object. the mass object had lines that were slightly off axis once i fixed the warnings in both profiles of the mass and updated the faces the detail component returned to its proper state.
dunno why only the detail component gets fubar'd but have discovered 'Lines slightly off axis' are causeing numerous issues with panels and mullions in hosted systems
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
