I am trying to create a custom curtain wall which will contain vertical strapping for the vertical mullions and horizontal wood boards. I created the two profiles and am able to create the curtain wall type control spacing etc...This looks great in elevation and plan, but when I cut a section detail the vertical strapping is cut at every horizontal mullion.
My question in short! If I want to create the look of continuous horizontal boards how can I prevent the vertical mullions from being cut? I'd rather not offset them apart so I can use this model element in details. See the section detail view attached.
Jesse
Hi Jesse,
I'm not sure I'm visualizing this correctly. Could you post a couple other screenshots to help clarify how you've built the wall, or perhaps a small sample file?
