I am trying to design the border mullion of the curtain wall, in a way that its centerline alignes to the border gridline.
For default the border mullion aligns the external face of it to the gridline,
but I would like it to act as the internal mulluon - aligning with the centerline.
How can I make it?
Thanks a lot!
Constantin Stroescu
This will explain better my issue.
https://docs.google.com/file/d/0B9wW_0_r5bZqLWo2dVR3QmFoUlU/edit?usp=sharing
In my opinion there is a sort of paradox here. You try to place a mullion outside his host"s limits...and normaly this can not be allowed. Maybe it could be possible to do it by using Window Family (editable family)....but not with Curtain Walls because they are System Family.
I'll try to put the problem slightly different , in a way a was confronted with in my work...
The problem appears when I wanted to split a curtain wall in a number of equal panels...
The distance between the Curtain Grids is equal , so it is that from the left border to the first grid and that from the last grid to the right border. That "s fine, but when putting the mullions , that on the border will be not centered on it, but of course inside it...that means that the first and the last panels will be narower by half mullion width.
How a did solve the problem in my project:
Constantin Stroescu
