Curtain Wall Issue-Please help
2 REPLIES 2
136 Views, 2 Replies
How can I get the curtain grids to be vertical and not follow the curvature. Please see attached. Any help is greatly appreciated. Tony
2 REPLIES 2
I guess this is a model made using mass modeling.What if you just make a wall from the beginning and not tell Revit that this face of the mass is a curtain wall.
JeffreyMcGrew
If you make a Curtain Wall using the Curtain System From Face tool in the Massing toolbar, you'll get mullions that follow the massing.
If you make use the 'Create Wall From Face' and set the Wall Type to be a Curtain Wall prior to selecting the Mass Face and making your wall you should get a curtain wall with mullions that are properly horizontal/vertical...
Rail Community
