Revit Architecture
Member
aa366
Message 1 of 7 (546 Views)
Curtain Systems in Curtain Walls
546 Views, 6 Replies
06-28-2012 11:16 AM
I have attached two files. One is a screen shot of a model. The other is a photo of a house I am trying to describe with the model. I am having an issue creating the windows. Also, I am not sure how to create the skin. I have researched making the walls curtain walls and embeding other wall information including a sweep into this curtain wall to create the look seen here but I am having no luck doing this. Please reply if you have any suggestions or a procedure that will help me achieve this. Thank you.
Alfredo_Medina
Message 2 of 7 (521 Views)
Re: Curtain Systems in Curtain Walls
06-28-2012 03:20 PM in reply to: aa366
  • The windows could be curtain walls, embedded. (That's a property that needs to be enabled in the C.W. type).
  • The skin could be another type of curtain wall, in front of the masonry walls, with empty panels, and with horizontal mullions and borders, only. To make room for the 'windows' and door, you need to edit the profile of the skin curtain wall.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Mentor
vector2
Message 3 of 7 (506 Views)
06-28-2012 09:28 PM in reply to: aa366
Curtain walls don't go in houses, windows go in houses.
Make the windows in the family editor or make them
in-place.
Edit: There are no curtain walls here, only doors and
windows of the door and window category. If they were
curtain walls, this would not be a house
Alfredo_Medina
Message 4 of 7 (484 Views)
06-29-2012 05:00 AM in reply to: vector2
in-place.
.... If they were
Not true. The Curtain Wall is a very versatile tool. You can create windows, window-door assemblies, aluminum panel claddings, rainscreens, 'skin' coverings, railings, etc; some people have used this tool to model pre-cast concrete wall panels.
Imagine the time it takes to create a window in the family editor, for every configuration of mullions that you need, when you can just create the window with the curtain wall tool, and simply place the grid lines wherever you need, as many as you need. Then, you can place this 'window' inside a wall.
Also, it is not true that if there were curtain walls, this would not be a house. Some houses do not even have punch windows, but are covered in glass all around. Some classical examples in architecture are Mies' Farnsworth House, and Philip Johnson's Glass House.
Alfredo_Medina
Message 5 of 7 (443 Views)
06-29-2012 06:50 AM in reply to: aa366
An example of how the Curtain Wall tool could be used in multiple ways in a house like the one shown in the original post:
Member
aa366
Message 6 of 7 (370 Views)
07-04-2012 04:47 AM in reply to: Alfredo_Medina
Alfredo,
Thank you for taking the time to work on a solution to my question. Could you provide the steps I would need to follow to produce what you have described?
Alfredo_Medina
Message 7 of 7 (357 Views)
07-04-2012 03:09 PM in reply to: aa366
An overview of the procedures is already posted in message # 2 above. Please use that as orientation, to research for more information in Wikihelp articles about Curtain Walls, Curtain Panels, and Curtain Wall Mullions.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
