Crop Region not in print
3 REPLIES 3
rsabclin
7813 Views, 3 Replies
I have made crop region lines to be heavy lines on elevations and it shows heavy lines on my monitor . When I created PDF file or print preview, it does not show any heavy lines of crop region lines. Anyone can help me with it? Thanks.
3 REPLIES 3
CoreyDaun
in reply to: rsabclin
While in the Print dialog, click on "Setup..." which will bring you to 'Print Setup' where you will find a checkbox option towards the bottom "Hide crop boundaries" that I believe is enabled by default. Simply clear that checkbox and your Crop Regions should print.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Jordan24MVU
in reply to: CoreyDaun
Does this print the crop boundaries in every view on every sheet that you print?
Or does it only print the crop boundaries that are turned on?
Thank you in advance.
in reply to: Jordan24MVU
Only the ones you turned on.
Rail Community
