Revit Architecture
Active Contributor
jesser
Message 1 of 6 (622 Views)
Crop Region Control
622 Views, 5 Replies
11-01-2012 08:42 AM
I am trying to find where to control the Crop Region Line.  I'd love to be able to creat view templates to control visibility and also Line Weight.  Currently we are turning them off per view.  and only want it on for 3D View and Interior elevations.
I know that by selecting each view crop region, right clicking and overriding by element I can control the weight.  Does anyone know a universal way or where in view templates to set this?
Jesse
Jesse Remick
"Sometimes the solution is so clear you see right through it."
*Expert Elite*
Alfredo_Medina
Message 2 of 6 (610 Views)
Re: Crop Region Control
11-01-2012 12:22 PM in reply to: jesser
The edge of the crop region can be overriden, but I think that change is not part of any view template settings.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
*Expert Elite*
Message 3 of 6 (606 Views)
11-01-2012 12:27 PM in reply to: jesser
Try highlighting the Crop Region, then right click and "select all instances in entire project", then override graphics.
Does this change all of the Crop Regions?
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
*Expert Elite*
Message 4 of 6 (596 Views)
11-01-2012 01:30 PM in reply to: ccollins
I just tried this--it does not work . i.e. it does not change all Crop Regions in Entire Project (tested Revit 2012).
Cliff B. Collins
St. Louis, MO
Active Contributor
jesser
Message 5 of 6 (594 Views)
11-01-2012 01:33 PM in reply to: jesser
That is what I've found.  Is there any way to change the default?
Jesse Remick
*Expert Elite*
Message 6 of 6 (588 Views)
11-01-2012 01:40 PM in reply to: jesser
I'm not certain of this, but I suspect that the Crop Region/Viewport is a "hard-coded" system family attribute,
as it applies to all View Types, and probably cannot be changed globally from within Revit.
The API may have tools/ability to change it? I'm not an API guru, but you might try searching.
Cliff B. Collins
St. Louis, MO
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
