Crop Import Symbol?
2 REPLIES 2
1088 Views, 2 Replies
Crop Import Symbol?
Hello!
I have a question for Revit Arch 2013...I linked a cad file into a sheet for revit and everything is working fine, BUT, the "viewport" for the symbol is very very large. This creates a problem when I go to print to scale, because I have a massive blank space.
I've checked the cad file, and there is nothing that is making the symbol bigger, to my knowledge. I also dont know if I can crop this symbol...?
Any help would be appreciated, Thanks!
2 REPLIES 2
LisaDrago
Have you adjusted the crop region in the view?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
I ended up cutting and pasting it to a new file and then reloading it into the revit file. I just assumed that there was some junk in the corner of the file that I couldn't select and delete. This did end up working, but I still don't really understand what went wrong exactly. Lara Lekang Architectural Technician [Description: Description: Description: ARTEKTA LOGO 7 cropped] 406 N. Broadway Fargo, ND 58102 p. 701-526-3693 f. 701-526-3694
